mrt2you
i have a LOT of parts laying around that i have no use for any more.
ALL PRICES ARE PICKED UP IN NEW BERLIN WI 53146 zip. i live 1 mile off I-43 and racine ave exit.
NO I WILL NOT SHIP. selling parts CHEAP and will be worth your time to pick the parts up.
GT500 parts
1 block from a 07 basically complete with crank, 7 rods and pistons,oil pan, oil pump, oil pump pickup, and lower timing chain gear. 1 rod didn't want to stay in the block and made a hole in the sidewall.
1 bare 08 GT500 block with main caps and nothing else. a few pistons melted down and scored the side walls. should be able to clean up with a bore job.
15 pistons and 16 rods. some pistons are melted. some pistons are from the bare block and some pistons are from a 2011 block i bought. there should be enough good pistons and rods to make 1 motor.
https://imgur.com/PWEVNEu
https://imgur.com/hqB3KGD
https://imgur.com/bN8llmA
https://imgur.com/FQ2IrVP
https://imgur.com/WxYufDF
https://imgur.com/qcou25d
https://imgur.com/8rOtzM0
https://imgur.com/qCX9v4P
https://imgur.com/KqVu5OK
$200 PICKED UP for both motors, pistons, rods, and the engine stand.
07 GT500 low miles complete struts and rear shocks from a 07 convertible
https://imgur.com/keeaFvV
https://imgur.com/6R4gdkT
$50 PICKED UP
1 GT500 bottom of hood insulation pad
$25 PICKED UP
https://imgur.com/8u1f6Mi
https://imgur.com/uLfdNpi
a set of 18" goodyear F1 tires. 2 p255/40/18 and 2 p285/40/18
$50 for the set of 4 tires PICKED UP
https://imgur.com/r5JKR3O
https://imgur.com/uxLYCE5
https://imgur.com/7icmd3D
https://imgur.com/4BE3A1I
https://imgur.com/BetLjBv
GT PARTS
i have a alloy block from a s197 mustang. it has no main caps but i found some laying next to them. not sure if they are for this block but you should be able to use them. includes windage tray.
$150 PICKED UP
https://imgur.com/zM0lnrL
https://imgur.com/0hoMV7J
https://imgur.com/euRHr5P
https://imgur.com/lu9PEeD
2 stock air intake boxes $15 PAIR PICKED UP.
https://imgur.com/677Mip1
stock 4.6 intake manifold with cm plate and motor $25
https://imgur.com/ASNA8Jl
FROM a 2012 GT ht. complete stock suspension. front struts, rear shocks, front and rear sway bar, panhard bar and all of the bolts and brackets to mount them.
https://imgur.com/wIKeE6L
https://imgur.com/fm1GYsT
https://imgur.com/xfOi03U
$75 PICKED UP
lincoln mark VIII parts.
i have a coil over conversion suspension with both front knuckles. a pair of exhaust manifolds, fuel rails with injectors. pressure regulator and a power steering pump.
https://imgur.com/3pNzFuy
$25 for everything
i have a core 4R70 auto trans with torque convertor. i think it was removed from a 02 mach 1 mustang.
$100 PICKED UP
https://imgur.com/Kbq6vO2
https://imgur.com/9cxxZWf
https://imgur.com/BsiQYyr
https://imgur.com/dVQB27z
GT500 parts
$50 PICKED UP
$25 PICKED UP
GT PARTS
$150 PICKED UP
$75 PICKED UP
$25 for everything
$100 PICKED UP
