sinabite
- Joined
- Jul 9, 2010
- Posts
- 210
- Reaction score
- 2
Question, I have an 09 V6 that I have had ALOT of problems with over the last couple of months with starting. More often than not, when i put the key in and turn.....NOTHING happens, the gauges move and you can hear the solenoid but that's it.......car will not start.
However, when i hit my remote start button on my alarm, it starts right up NO PROBLEM. Sometimes, after the car has been running for awhile if i jump out and run into a store or something then come back the key works fine.....but not always.
Basically, i have to use my remote start 85% of the time to get the car cranked.
The spark plugs and battery are less than a month old.....thought these were possibly the problem. My only guess is possibly a bad relay in the ignition switch?
Curious if anyone else has had this problem.....if so how did you fix it, and how much did it run to have fixed.
Thanks
Justin
Thanks
Justin
