TheRookie65
NEWBIE
^^^ Is that something he can do or does Ford have to do it?
I am 99% sure your car just need needs the Misfire Monitor / Neutral Profile Relearn procedure done again. Mine had exactly the same symptoms and this cleared it up..
Call me crazy, but it sounds like they have investigated every possible option other than the fact that it could actually have a misfire ...
the tech said it has a misfire but they cant determine why. it's doing it on all cylinders. I drove the car hard on the way home after picking it up( harder than i have since i got it) went to 6500 in first 3 gears with no issues so far.
If the misfires are across the board like you say they told you, I'd recommend new plug if this was a car/truck with a bunch of miles on it, but a new car, that tends to make me think the PCM is not working right, or a bad ground, maybe even a bad ground for the fuel pump, or a bad fuel pump.
These are all things they could've checked, except maybe the "bad PCM" part ... contacting Ford's Tech Hotline would've been my next step, even as an Advisor (not a Tech) I've done it many times when the tech would throw his hands up in the air and walk away, and I'd come up with another test for him to do ... more often than not we'd end up finding/doing something to the car, not just shipping it ...
You might be.surprised how many brands come from the.same.place with the additives being the main.difference.
