Mick
Morris you are 100% correct.
Hell soon would've been a year ago.
so far my problem has not come back. I have taken it out to 6500 rpm in a few gears just to be sure.
Never happened to me under hard acceleration, only when holding 3rd or 4th above 4K.
This is bizarre indeed. Curious to see what finally happens here.
Bald, how long where you at a given RPM? My car had a similar issue when I was in third gear at 4k for 1/4 of a mile because I was messing around with the radio..... After that it never did it again.... Cause I never drove that long at that RPM..... I did some internet research and found two other instances.... one a stock 2011 gt and a stock Boss..... Not saying thats your problem but just wondering about how long at a given RPM did this happen....
Just an FYI if they said they checked the coil packs and they tested fine you might want to have them change the coil packs anyway, alot of electronics test fine under no-load conditions.
I had to fight with my dealer to get them to try a coil pack when I had a misfire holding the engine at 4k rpm for more than 2 seconds. they cleaned my injectors, flushed my fuel system, changed my fuel filter, air filter, gave me a new MAF and said the coil packs tested fine, I got sick of it and told them TRY to change the coil packs PLEASE I will pay for them if it's NOT the coil packs.
guess what?
a coil pack was going bad under load but tested fine on the bench.
jerkoffs.
