RedMosesSC
Fellas,
I tried searching for ppl with simlair issues but dint find anything, so here goes.
06 Saleen, 25k miles, 3650 trans with MGW shifter, CHE torque Brace w Limiters, McLoad RST Clutch/Flywheel. I bought the car with 5k miles and the trans was always notchy, from day one when i put it in first i hear a slight "Bang" in the trans case. When i put in the MGW i blew the input shaft within 20 min, Ford fixed it under warranty. The car started with 430 crank hp and over the 3 years its up to 420 WHEEL HP, the trans has gotten more notchy as the power was added.
Lately, i have to wrestle to get the trans into first or reverse but if i shift into 3rd gear and then go into first it does in smoothly with minimal effort. Its almost as if the trans is not lining up witht he shifter but once its put into 3rd it all lines up when going back to first.
The westling is getting progressivly worse, i need to know if there are adjustements that can be made or this trans is just toast. While driving the trans shifts well and hold up to the power but from a stand still im fighting to get it into 1st & Reverse, any one else come have this issue?
