- Joined
- Jul 30, 2012
- Posts
- 1,449
- Reaction score
- 34
I just updated Tapatalk as the version that was on here was OLD!
[SIZE=5]Log In Failed[/SIZE]
Server error occurred: 'require_once() [function.require]: Failed opening required './global.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') (config.php:20)'
It's definitely broken. When I attempt to log in, I get this error message:
That looks like pretty fundamental breakage to me. Please fix!Code:[SIZE=5]Log In Failed[/SIZE] Server error occurred: 'require_once() [function.require]: Failed opening required './global.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') (config.php:20)'
Try it out now.
Failed to process XML Data due to unknown error.
I'm replying to you on Tapatalk. No issues here.
Seeing I just installed it instead of trying to mess with it, I just uninstalled TT and then installed it again. After that it was working fine. Have you tried uninstalling it and installing it back on?
I uninstalled/installed it and it's working now, just have to get use to this wacky layout.
Is it totally different? Like I said, first time user. Always view the site on my phone with the browser.
Immensly different.
In a good way or bad?
