Team JDM/ Ford Racing "Aluminator" 3v Longblock
JimIII@JDM
JDM Engineering is proud to introduce a new line of fully assembled Ford Racing 3v Long blocks. These engines will be assembled by hand using Ford Racing aluminator short blocks and Ford Racing CNC ported cylinder heads. Three different stages of the long blocks are offered, each has a higher power rating than its predecessor. This is done by using 3 different sets of camshafts (Stock, Ford Racing Hot Rod, and Custom JDM spec Comp cams) each will bring your engine to next level of performance! Brand new factory Ford head gaskets, head bolts, timing components, and cam phasers are used to complete the engine build. Every engine is inspected, assembled, and timed to specification in house by Matt Kennedy of JDM Engineering racing engines. This new program using Ford Racing components follows the same guidelines of our already highly successful 298 Stroker program that has been running for nearly 4 years now. Team JDM stands behind each build and guarantees satisfaction with in every engine.
*Every engine comes fully assembled however several items may be required for installation such as a new oil pump pick up tube or covers like an oil pan, timing cover, or valve covers. Also an 8 bolt flywheel will be required while installing any of these engines.
Stage 1: Offers the ability to handle up to 700 engine HP at a minimum cost. The Long block is assembled using stock Ford camshafts and valve springs giving you factory idle quality and driveability. This engine is perfect when making under 600 rear wheel horsepower. While using stock camshafts you will not see much of a power change from a factory Ford engine. However with the forged aluminator rotating assembly you can add power at will via boost or other methods!
600 HP rated
6500+ RPM power band
Retail price: $6895.00
Includes:
Ford Racing Aluminator forged 3v short block 8.7:1 compression
Ford Racing CNC ported heads w/ stainless and inconel valves
New Ford head gaskets, bolts, timings components, and cam phasers
New Ford 3v oil pump
New Ford 3v camshafts
Fully assembled and timed by JDM Engineering
Stage 2: Comes ready to rumble with a set of Ford Racing Hot Rod cams used to raise the power level and RPM band. This engine is built to the same specifications as the stage 1 including factory ford valve springs. The hot rod camshafts are designed to be used with factory Ford valve springs and cams phasers. Lift is raised from stock by 1mm which promotes a higher RPM band and peak power gains. The duration is raised for a aggressive idle sound and mid range power improvements. The long block still maintains capability to handle over 700 HP but will achieve as much as 40-50 more horsepower from the factory Ford engine.
650 HP rated
6800+ RPM power band
Retail price: $7595.00
Includes:
Ford Racing Hot Rod camshafts
Stage 3: Same base build as the first two though a set of custom Comp camshafts, high performance valve springs, and steel retainers replace the factory components. Team JDM has worked closely with Comp cams to design a custom grind cam that will give your 3 valve engine maximum performance. These cams have over .530” of lift and a custom duration spec held proprietary to JDM. With the higher lift cams a set of Comp phaser limiters are required to ensure your engine does not have clearance issues in the event of a phaser failure. The limiters allow up to 20 degrees advance or retard which gives your tuner the ability to still work with VCT. Peak power gains over 70 rear wheel horsepower have been seen during testing on our in house dyno. The major difference between this engine and the stage 1 or 2 is the valve train upgrade. High pressure Comp valve springs and steel retainers are added to improve valve train stability. With higher seat pressure valve springs you have the ability to run more boost pressure as well as raise the engines peak RPM. This will result in more power and performance for your Mustang!
700+ HP rated
7000+ RPM power band
Retail price: $7995
Includes:
JDM custom grind Comp camshafts
Comp high pressure valve springs and steel retainers
Comp cam phaser limters
*We also offer an Oil pump upgrade which includes a brand new GT500 SVT O ringed oil pump using TSS billet gears for an additional $350.00!!
**Shipping and handling is seperate from the prices posted above. Usually between $400 and $600 depending on your location.
***These are available on a 1 week build time!!!
Please contact us at 732-780-0770 during our office hours or email [email protected] for questions or to place your order!
M-6009-A463SC* Ford Racing Aluminator Shortblock for Supercharged applications
Fits 2005-2009 Mustang GT
Forged steel 8-bolt crankshaft
Forged steel H-beam connecting rods
Forged aluminum 16cc dish 3 valve pistons
New oil pump
Uses M-6010-A46NA block, knock sensors are not removed from the block
Approximately 8.7:1 compression ratio when used with 50.3cc 3 valve heads
Lower compression for supercharged applications
Built with all NEW PARTS
M-6049-N3VPA & M-6050-N3VPA Ford Racing CNC ported 3v cylinder heads
New production cylinder head castings
CNC ported to increase flow and performance
50.3cc combustion chamber
Intake flow increased appoximately 20%
Exhaust flow increased appoximately 30%
Assembled with production springs, valves, retainers, locks, and seals Does not include camshaft, followers, and hydraulic lash adjusters
No exchange required Requires
Uses 2008-2010 12 MM spark plugs
JimIII@JDM
Holy shiiite thats a good deal, do you guys do financing ? LOL
haha, it is a great deal isnt it! We dont offer financing but there are a few companys out there that will make loan approvements for automotive enhancements.
irishpwr46
Official Site Vandal
NYC
shit if i had known about this two weeks ago i would have had ford put one of these in my car instead of a new stocker and i would have paid the difference
IIRC they used to get $2K...... maybe Jim III can work out a deal for a member on parts and install.....????????????????????
JimIII@JDM
What would installation run on one of these if you did the install?
We get $2500 now for complete R&R on these and we will throw in a dyno tune if your taking advantage of this in the near future!
R&R?? repair and replace?
JimIII@JDM
I guess you could make it mean whatever but I guess Remove and Replace is what that means. We will pull the old motor out remove the old accessories and components and swap to the new long block then re install it in the car and get it running.
RetroGT2006
06 S197 Member
Florida
Very nice deal, can't wait to put a motor in my 06 GT! A stronger motor with boost that is =)
1MEANSALEEN
Jersey Shore
for the stage 2 package what size pulley combo would be needed with using a saleen blower to make over 600rwhp?
JimIII@JDM
A 2.87 with an overdrive lower pulley to make around 16 psi to get there
