01yellerCobra
This is on my 2001 Cobra. I have a Raptor shift light in my car. When under boost it will flash like it's being reset sometimes. It never did this when I was NA. I'm already planning on closing the gap a little since I have a stutter around 3500rpm. Would a missfire cause the light to flash like that? The light is connected to the number one COP at the ECU per the I instructions I used when I installed it years ago.
The set up is a BB/stroker, Vortech T trim, NGK TR6's gapped at .026". I'm planning on re-gapping them to .024" or .022". I'm not completely sure of the boost level. Last I was able to check I was hitting 15psi around 5K, but then my boost gauge started sticking at 11psi. I found that out when I hooked it up to my air compressor. A/F is 11.4-11.6.
I know it's not an S197, but like I said, you guys are on the smart side compared to others.
