cagefightmma
After installing my Edelbrock S/C, I took it to get dyno'd and my numbers were 396 rwhp and 395 rwtq (uncorrected I believe). He said my TCI 3000 stall speed convertor was slipping during the pull which made my numbers lower than expected. Where the converter slipped, you could see on the dyno graph that it dropped a bit. When it dipped the fuel pump also started running low on fuel so he suggested to go with a BAP. He said with the amount of low end torque, the converter and my 4.10's is not the best combination for a daily driver. This combo worked really well without the S/C. I am thinking about putting my factory converter back in or maybe buying an PTC converter with maybe less stall speed, maybe 200 rpm above stock. Does anyone know what the stock converter stalls at? Any input would be greatly appreciated.
