ebrow21
I've spent a fair amount of time trying to find this out through search and have not found a direct reply, so I figured it would be best to ask. I know every vehicle is different, but I would like a frame of reference if possible.
A quick rundown.
06 Gt Convertible auto
HT0's gapped .31
NX stand alone fuel cell running C16 with nitrous, 93 octane in the car.
125 shot 57n/33f HSW plate with NX solenoids (11.0-11.2:1 AF)
Other expected assorted bolt on's.
The car was dyno tuned on nitrous and ran fine pulling 5 degrees of total timing full throttle. Datalogs show around 26 degrees total timing while on the nitrous tune. On two separate occasions, the car has run great the first half of the track, laid over the 2nd half of the track, and burned the plug under the fuel rail pressure sensor. My wideband is on the on the same bank as the burned plug, and throughout the entire run it never went more lean than 11.2:1. All the other plugs checked fine, and weren't changed after the first plug was burned.
I'm thinking the cumulative heat from the run is eating that plug at the end of the run, where it wouldn't do so on a single dyno pull. It just seems odd to burn the same SINGLE plug twice if its tune related.
I am getting the injectors flow tested, putting fresh c16 in the cell, and have a tune with the option to pull more timing. The car compression and leakdown tested fine. Before I run the car again, however, I would rather have some input from other nitrous users.
To give you and indication, the car went [email protected] in the 1/8th and then went [email protected] in the 1/4 on the run it burned the plug.
Those who have run nitrous on their car and datalogged, what has your total timing looked like?
A quick rundown.
HT0's gapped .31
