TPS Mustang (05-12) Stainless Steel Brake Lines
w/ ABS-$119.99 FREE SHIPPING
Click here to order
http://www.tpsmotorsports.com/musta...less-steel-brake-lines-05-12-4-wheel-abs.html
TPS Stainless Steel braided brake lines are made using extruded Teflon hose and is braided with stainless steel and permanently crimped on each end. All TPS Stainless Steel brake lines are made to MVSS-1066 specifications, meeting D.O.T. Certification. TPS Brake lines carries a limited life time warranty against all manufacture defect! All TPS brake lines are made in U.S.A to ensure they the highest quality product!
Benfits of TPS S.S brake lines:
* Kit comes with everything you need (banjo and washers) to mount the set. 100% plug and play install. No modifications needed.
* Coating is designed to resist weather, chemicals and abrasion for long term value.
* Increase your brake feel and increase pedal response. Eliminate the spongy factory installed rubber lines which expand during braking.
* Eliminate brake "fade" while giving better mid-braking feel across the entire spectrum.
* Reduced volumetric expansion
* Shorter braking distance
* Fits ALL 2005-2012 Mustangs with ABS
Click here to order
