So due to the lighter aluminum flywheel I have noise during idle which is liveable but what I can't live with is during low gears the gear lash or whatever noise it makes often described as "marbles grinding" or "coffee grinder" is just a plain awful.
I currently have the original mercon atf that ford put during assembly. And based on this article, a thicker blend of atf can help?
http://www.uucmotorwerks.com/flywheel/gear_rattle.htm
