Roadracer350
OK guys I have a question. How do you PERMANITLY disable the traction control on the 05-09 GT.
I am spending all my cash on the FR for now.
Yeah I been thinking real hard about a FR/BRZ. Wish I had one. I tell myself I would only change dampers and springs...maybe rims ....CAI and tune....turbo....ah screw it. Better just stick with what i got for now.
I didn't even realize. Thanks for pointing it out. I assumed the link was just pointing to a thread where someone has already asked how (with the normal "have your tuner" do it).It can be set to off by default if you do what is said in JesseW's link. I did that mod, took a couple hours. Everytime I start the car it starts in the off position. If it starts to rain or gets slick, hit the button and turns back on. Works great.
I wish you could turn it off in the tune, but still turn it on when needed. When it's disabled in the tune... it's disabled.
Too bad it can't be set to "off by default".
Sent from my Galaxy Nexus using Tapatalk 2
I haven't messed with it in the tune, other to disable it using SCT PRP. At any rate, I didn't like it disabled all the time, because it has definitely helped in the snow/rain. I'll definitely be doing the relay trick.Yep, I've turned it back on for the time being. Have you ever thought about trying different values? Stock is 46, off is 0. I tried 23 once just to see what would happen but it tripped the fault light just like when it's turned off in the tune which meant the switch was disabled and I couldn't turn it off.
I've also thought about progressively setting limits on the tb. Something like a 50 degree blade limit at 1500 rpm, 65 at 2000 rpm, etc. To help control launch. Just have to wait for the weather to cooperate.
Ok so let me get this streight... If you go with the disable in the tune you cant turn it on or off and the light is on all the time. If you do the relay deal when you start the car the TC will be off but the light will be off. When you hit the button to turn it on how do you know its on? Do you have to shut the car off then restart to shut it off?
