Trick flow is just that. It has a dipstick and isn't much thicker at all. My headers hang lower.
No, mine is Trick Flow and holds 2 extra quarts and is finned aluminum with a dipstick.
I would show you the spot at Summit if I knew how to post a web site... I'm old.
If you have a Brenspeed stage 3 engine and all like I have, you have one badass car.......
The new pan will help only a little. It's been 90 and humid here and if I go 20 or so miles I'm at 190. My transmission guy says that's ok and I should change my guage to watch something else and just drive it.
Thanks for the pics, that is bad ass....
hmmm, did 4 WOT runs yesterday quickly after each other to log the current tune and saw the trans temp rise till 227 after the last one ...
My brakes also started to fade after the last run
Cooler installed, pan with dipstick installed, all that's now left is to find the correct way to check the fluid level.
So many opinions on how to do it correct.
Everybody says with hot fluid but some say about 100°F others 170°?
Engine running in N or in P?
Even read it should be in D with the wheels spinning. Car on stands off course
It sometimes still acts strange
Stopping for a trafficlight while in D and the car wont move. Give some extra gas and than it suddenly kicks in. Same when I go to R, it sometimes takes a sec of 5 before it moves.
Yet another question that pops to mind.
The manual states to position the vehicle on a hoist and set is as close to level as possible.
Do they mean the car as close to level as possible or the oil pan that is normally under an angle when the car is leveled on the ground???
