Dubstep Shep
WUB WUB VROOM VROOM
Essentially: used to emphasize the basic, fundamental, or intrinsic nature of a person, thing, or situation.
Draw your own conclusions, I don't care.
essentially (ɪˈsɛnʃəlɪ)
adv
1. in a fundamental or basic way; in essence
no those transmissions are very different. 6 gears is about the only similarity.My thoughts exactly...
The 6060 and the t56 are essentially the same transmission.
I conclude you used the first definition google turned up
My conclusion is I am now reminded why I do not respond to your posts.
i had that issue in a 2012 model racing a built ws6. not up to date on the ford issues vs fixes but I've driven both, the 6060 doesnt like the powershifting, the magnum is awesome on the track especially with the direct short shifting. not dogging the 6060 but if the op is looking for 6 spd i would rate the magnum xl ahead of the 6060 by far for function, feel, and performance hands down but it does come at a steep cost so if money is a factor then 6060 is the way to go.I just haven't heard of any issues (nor have I experienced any) with the GT500 6060 transmission except for the first model that had a slightly oversized input shaft and would hang on the 1-2 shift. That problem was cleared up right away though.
Since I hadn't heard of anything I was hoping for some information from woody.
the case is different alsoThe 6060 is a T-56 variant according to Tremec. I was under the impression that the Magnum was a 6060 with a different tailshaft and a non integrated bellhousing. The tailshaft allows for direct shifting and the bellhousing allows for sfi compliance.
on a side note, a twin disc spec does help out alot on either front
wish i could give you the engineering details but i can just give you drivers opinion which we all know is like assholes, but i can say this also the magnum is a fucking boulder, even without the scattersheild bolted up it is ALOT heavier than the 6060 also and you will be hard pressed to muscle one in by yourself
I thought it was from cranking on that torque wrench 1,000,000,000,000 timesBruce is buff from moving all his engine blocks around!
Every GT500 from 2007-2014 has had the TR6060.
your trans is the one that is being contemplated swapping the magnum for. you've already spoken to the gentleman. and your welcome, i sold your fuel system to him last week also.4r70w/ thread
