trunk push button
silverstang23
Marietta, GA
Is their a ground wire on the drivers side, some where near the steering column? It would be more convenient to have it on the drivers side. Also, what kind of wire is needed for this?
Redfireshaker06
Central Florida
I just soldered on 2 14 gauge wires I had at work. There was a grounding bolt already used on the passenger side. I put it where it was stock in all the other years. Fit perfect. if you use the ford one it doesn't get tripped when a knee hits the glove box. Just find some metal and you will be fine. I think theres some by where your right leg would rest. Just unbolt one of those bolts behind the plastic and attach the wire there. Any wire would be fine. 14 or16 gauge should be good. All its doing is grounding the wire, which pops the trunk.
silverstang23
Marietta, GA
So i have finally found what i think is the correct wire. I have installed the button with 12 awg wire. I didn't solder the wires to the button, I just twisted them together and taped them off. I cannot get the button to work. Can someone help me with this? The wire i am using is white with 2 think hot pink lines. I grounded the second wire to the grounding screw already used.
QWKSNKE
This be the switch.
OMG! that is freaking hilarious. I must have one!!!
08blackchrome
Where Did you get that. i would like to have that, but I would like to have a bottle heater switch in place of the trunk monkey lol
grampa_stang
Mine didn't work at 1st either. I found the wire in 2 locations behind the passenger kick panel. So, start looking in the other group of wires.
KIMMER
Admin
I still have to do mine. I'll start looking for a wiring diagram to fine the correct wire/color.
KIMMER
Admin
Found this from the days of doing car alarms..lol Looks like white/purple in the passenger kick panel/harness for the (-) wire.
2005 Ford Mustang Car Alarm and Remote Car Starter Wiring Information
Constant 12V+ Wire: Light Green/Purple
Constant 12V+ Wire Location: Ignition Switch Large Harness
Starter Wire (+): Dark Green
Starter Wire Location: Ignition Switch Harness
Second Starter Wire (+): N/A
Start Wire Location: N/A
Ignition Wire (+): White/Yellow
Ignition Wire Location: Ignition Switch Harness
Second Ignition Wire: N/A
Second Ignition Wire Location: N/A
Accessory Wire: Black/Pink
Accessory Wire Location: Ignition Switch Harness
Second Accessory Wire: N/A
Accessory Wire Location: N/A
Key Sense Wire (+): Light Green/Purple
Key Sense Location: Ignition Switch Harness
Tachometer Wire: NOT Red
Tachometer Wire Location: Use any ignition coil or fuel injector.
Door Lock Wire (-): White/Purple or Orange/Black
Door Lock Wire Location: SJB, black 26 pin plug, pin 3 or 8. The SJB (Smart Junction Box) is in the passenger kick panel. These wire are also found in each kick, in the door harness. The first wire listed is the driver switch wire and the second is the passenger switch wire.
Door Unlock Wire (-): Dark Blue/Light Green or Yellow/Red
Door Unlock Wire Location: SJB, black 26 pin plug, pin 1 or 5. The SJB (Smart Junction Box) is in the passenger kick panel. These wire are also found in each kick, in the door harness. The first wire listed is the driver switch wire and the second is the passenger switch wire.
Door Trigger Wire (-): Use dome supervision wire.
Door Trigger Wire Location: N/A
Dome Supervision Wire: Light Green/Yellow
Dome Supervision Wire Location: SJB, gray 26 pin plug, pin 25. The SJB (Smart Junction Box) is in the passenger kick panel. Also found in the passenger side A pillar.
Headlights Wire (-): N/A
Headlights Wire Location: N/A
Parking Light Positive Wire (+): N/A
Parking Light Positive Wire Location: N/A
Parking Light Negative Wire (-): Black/Light Green
Parking Light Negative Wire Location: Parking light switch or SJB, blue 52 pin plug, pin 31. The SJB (Smart Junction Box) is in the passenger kick panel.
Trunk/Hatch Pin Wire (-): White/Yellow
Trunk/Hatch Pin Wire Location: Truck Light or SJB, black 26 pin plug, pin 15. The SJB (Smart Junction Box) is in the passenger kick panel.
Hood Pin Wire (-): Purple/Orange
Hood Pin Wire Location: Hood Pin or SJB, black 52 pin plug, pin 15. The hood pin wire rests at ground and goes to an open circuit with the hood open. The SJB (Smart Junction Box) is in the passenger kick panel.
Trunk/Hatch Release Wire (-): White/Purple
Trunk/Hatch Release Wire Location: Passenger Kick Panel or SJB, black 52 pin plug, pin 13. The SJB (Smart Junction Box) is in the passenger kick panel. The trunk release motor wire is pink/orange (+) in the passenger kick, harness to rear.
Factory Alarm Arm Wire: Light Blue/Pink
Factory Alarm Arm Wire Location: Driver Kick Panel or SJB, black 26 pin plug, pin 18. The SJB (Smart Junction Box) is in the passenger kick panel.
Factory Alarm Disarm Wire (-): Light Blue/Black
Factory Alarm Disarm Wire Location: Driver Kick Panel or SJB, black 26 pin plug, pin 9. The SJB (Smart Junction Box) is in the passenger kick panel.
Factory Alarm Disarm but No Unlock Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Horn Trigger Wire (-): Dark Blue
Horn Trigger Wire Location: Horn Switch or SJB, blue 52 pin plug, pin 39. The SJB (Smart Junction Box) is in the passenger kick panel.
Brake Wire (+): Light Green
Brake Wire Location: Brake Pedal Switch or SJB, gray 36 pin plug, pin 16. The SJB (Smart Junction Box) is in the passenger kick panel.
Emergency Parking Brake Wire (-): Red/Yellow
Emergency Parking Brake Wire Location: Emergency Parking Brake Switch or SJB, blk 52 pin plug, pin 50. The SJB (Smart Junction Box) is in the passenger kick panel.
2006 Ford Mustang Car Alarm and Remote Car Starter Wiring Information
2007 Ford Mustang Car Alarm and Remote Car Starter Wiring Information
ZmanM3
The Evil One
Jackson, NJ
Thats some great info there, thanks for posting!
KIMMER
Admin
That looks like the wire coming off the alternator.
WTF, where did that one come from? SOB, i'll have to change it...lol
Wow, refresh the page and photo changes to something else...that's messed up.
Leo_06GT
San Diego
Here's some preliminary pics of my install. Pics pretty much show which wire I tapped and where I grounded my other wire. I've decided to route the wiring into the armrest storage area and mount the e-brake access panel. I'll post pics of it once I'm done.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
silverstang23
Marietta, GA
So i have a problem. I was installing my trunk button, and now i think i might have blown a fuse. My two door mounted subs aren't working. You can hardly hear anything coming form them. Everything else works fine. Any help would be appreciated.
