Wnt2gofst
Banned
Ok so my car has been on the dyno for 2 days now. My tuner has been working on it. We also have had some help from Blow By Racing with there tune.
Anyway biggest issue is idle. It don't want to idle worth a shit on first start up. You have to rev it up to about 1500-2000rpms for the first 15 seconds or so. Then the idle will be ok. But once shut off it does it all over again. Then around 3000rpm's it has a stumble as well. Once you hit about 3500rpms all the way to 7500 it is great. Any idea's? There is some issues with fuel trim levels as well. I can send data logs to look at if need.
MODS: Paxton SC, 80lb injectors, BBK LT's, O/R X pipe, Boss intake, KB BAP. We had a 3.3 pulley on it but switched back to stock pulley.
We was seeing 14.5lbs of boost and from Paxton we should have seen about 11/12lbs of boost with the 3.3 pulley.
