Upgrade List
Meteorb64
Hey everybody! Little introduction here: So I've finally been able to replace my 2012 V6 Base Mustang with another daily driver (a Subaru Outback), and now I get to play with my Mustang :D
Bought the car brand new, have kept it to this point, and plan on hanging on to it until it's a classic. I know it's "just" a V6, but it's mine, and I don't owe anything on it, so it's the car I'm playing with.
Anyway, to the point:
Trying to put together a list of upgrades of things I may want to do to the car over the next couple of decades :rolleyes:
List so far:
ENGINE
Cold Air Intake
ECU Tune
Throttle Body
Throttle Body Spacer
Exhaust
Headers
High Flow Cat?
Super-/Turbo-charger?
DRIVETRAIN
Driveshaft
Safety Loop
Clutch
Flexplate
Torque Converter
Rear Gears
Panhard Bar
Rear Lower Control Arm
SUSPENSION
Springs
Struts
Sway Bars
Camber/Caster Plates
Coil-overs
Front Control Arms
IRS Swap?
TIRES/WHEELS
Tires
Wider (Rear)/Light Weight Rims
BRAKES
Pad/Rotor Upgrade
Fluid Upgrade
WEIGHT
Spare Tire Delete?
Rear Seat Delete
Carbon Fiber Parts?
EXTERIOR
Hood
Fog Lights
Head Lights
Tail Lights
Spoiler?
Body Kit?
GT front end conversion?
COSMETIC
Floor Liners
Pedals
Hood Struts
Badge Removals
Lambo Doors? (lol)
Things with "?" after them are things I'm less sure I want to do.
Anything you'd add/take away from all that?
Interested to hear your thoughts/opinions.
Also interested if anyone has a preferred "order" to do mods in, just out of curiosity - obviously some things make more sense to do at once, and the tune will likely need to be updated at various stages.
Happy Mustang-ing! :cool:
01yellerCobra
San Diego, CA
What's the goal for the car? That will help a lot with the decisions. From another thread on here I think it's debatable if throttle bodies are worth it. The spacer is snake oil. A turbo or blower could make the car a long more fun. No one makes an IRS to swap in. Unless you want to go custom.
As for the cosmetics, that's all up to you. It's your car.
Meteorb64
Ha! Didn't actually mean to leave the cosmetics on there. We'll edit that out in post >.> <.< >.>
My goals are increased HP and speed without losing too much maneuverability. Needs to still function as a road car, and have a decent ride, but I'd also like to blow past the occasional unsuspecting V8.
Mostly I just wanna play with the car for fun, and see what happens/do what I can with the goal of...doing it. /shrug
07 Boss
Sin City
Whatever mods you decide on build from the ground up. It's the best way to build it.
Meteorb64
frankly... trade it for a 5.0 if you want more power.
I know. That idea is still bumping around in my head, but I do really enjoy the idea of having a car that I've had since it was brand new, not just something used I picked up because it was more HP... hard choice for me.
Besides which, a used GT of the same model year is like 15-18k, rather than the few hundred I can start throwing into things now, and I don't want to add another car payment at the moment.
Forty61
Dallas, TX
Personal opinion, I wouldn’t go chasing big power numbers out of a 6-cylinder, I would be angling more towards the handling upgrades and getting some weight out of it.
Meteorb64
It'll never have big power numbers; it is just a V6 after all. But that doesn't mean I can't add a *little* more power. Drivability is the main thing, and it'll mostly be road driven, so it doesn't need all that much as far as brute HP anyway.
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
Do suspension, tires and brakes. Then wait until you can afford an F150 3.5 ecoboost swap. Start saving up and don't waste your time with the little bolt-ons that just chip away at your bank account and don't add much power. If you want performance out of a ford V6, might as well use the best one that they currently make. There are no shortage of them in junkyards.
With a tune, the one in my explorer sport absolutely rips. The torque and boost response is excellent. The sound, well that is not so good but at least the turbos keep it quiet.
Meteorb64
What makes the EcoBoost 3.5 so much better? And how much else needs to be swapped with it?
GT500 swap using a donor car
fin
It's my understanding that for the price of that you might as well just sell the car and by a 5.0, no?
Yeah, I'm excited about that somewhere down the line :-D
RED09GT
Forged internals, factory designed for forced induction, stronger block, direct injection, lots of experienced calibrators to work with, and a proven platform.
To do a power adder and forged internals with your 3.7 will buy you 2 junkyard F150 ecoboosts.
RED09GT
There are a few threads out there on various boards with builds similar to this. Your stock transmission and motor mounts bolt right up. You will probably have to re-route some of the turbo plumbing, use an aftermarket intercooler, and probably have to change fuel lines. The Ford racing controls pack will be the easiest way to get everything behaving like it came that way from Ford.
Search it on Youtube
Another plus is that it will be considered a "period correct" modification several years down the road.
Meteorb64
I really like the idea, but per https://www.allfordmustangs.com/for...-into-2012-mustang.html#/topics/949809?page=1 it ended up being about a 10-15k dollar project, which is way more than the 6k supercharger, lol. It'd be sweet, but for that kind of money I could buy a 5.0 mustang... will definitely do more research, maybe that guy overdid it, but it sounds like a lot of work to get the exhaust/headers, and even the steering and A/C working right...
Edit: also seems Ford put out a control kit for it, but it's only meant for M/T as far as I can tell, so I'd have to add an auto-to-manual swap in there as well.
DETROIT
What?? Look at the GN from 30 years ago. Forced Induction can do a lot.
I would lay out your goals and budget. you probably could find a wrecked 5.0 and do a proper swap for less then a FI 6 build.
