No boost for me (yet). Just wanted to make sure thats all it had to do with. Chuck do you happen to have the location for the ones on the manual cars? I have a feeling I am having a vac. leak on mine or something because while the car is running you can hear this faint sucking sound, then unhook the hose that comes off the check valve into the cold air and plug the outlet of the check valve and the noise goes away. Im hoping that this is where my idle miss fire feeling im getting is coming from since I went to ford and got the pcm reflashed as per the tsb and it didnt help much at all.
P.S. Scuba did you get rid of your lightning too? I remember you off LR, My username was the same on there
