Project Update for 28, 2014: In this project build thread update we will be showing more details of the repairs and upgrades to the TT3 Mustang after the shunt I had at RoadAtlanta in May. Next we cover another track day two weeks later at ECR, where Amy drove and tested out the repairs and brake system improvements. I talk a little about wheel bearings and have a video of what a bad S197 front wheel bearing sounds like. We also had a car show to attend in June with our Mustang to support a Vorshlag team member's custom Cafe Racer charity bike build. Finally I'll "weigh in" with more of my thoughts on the S550 Mustang's latest weight revelations. We'll save the NASA event at Hallett for the next installment.
Injury Report and Car Repairs after Road Atlanta Crash
When we got back from RA the car was a bit of a mess, but my back was in a little worse shape. I made a couple of doctor visits, where they X-rays and some pokes and prods, but not much else. I was determined to avoid any surgery and especially
spinal fusion surgery. Both doctors said "avoid any load on your back, don't go to the gym, lets look at you again in about 6 to 8 weeks", so I've been sticking to that plan. I dealt with the pain by taking Aleve daily, used an ice pack at night to reduce swelling, wear a lower back almost brace every waking hour, and had to take Hydrocodone about a dozen times when the pain got really bad (all from my doc's advice). Never missed a day of work but there were probably a few times I should have gone home early. Pain makes me more of an a-hole than normal, but Sofi would just yell into my office "you need take a pill!" when I got too far out of hand.
Sleeping has been very difficult, as all I had to do was roll on my side and the broken rib would spear me awake. I mostly slept sitting upright for the first 3 weeks and was getting about 2-3 hours a night. The rib finally felt like it was mended at about week 5 but the fractured vertebrae and nearby disc are taking a bit longer to heal. I don't have to exert myself or lift much weight to aggravate my back, so I keep the brace on most of the day. After 5 weeks away I finally made it back to the gym for some self-imposed physical therapy by week 6 and was off the pain pills and Aleve by then. It is week 7 now, I'm doing better, and have already completed two race weekends without any incident since the crash. It actually feels fine in a proper race seat and 6-point belts. With the next two months devoid of track events I can concentrate working at the gym to strengthen my back again.
The damage to the car actually wasn't nearly as bad - after a lot of checks and measurements it is still perfectly straight and unbent, just taking some superficial, cosmetic damage. This level of vertical impact could have turned many chassis into a banana, but the S197 unibody is a tank. After 4 years of just calling it "The Red Car" around the shop, I think a nick-name of The Tank is more appropriate now.
The gravel trap took the splitter off, and when that left the car it damaged some other bits that were bolted to or nearby it. The bottom edge of the front bumper cover was ripped off, which is a section hidden by the CS lower fascia but still integral to its attachment. The left side's black factory "side skirt" was also mangled and half torn off, plus the lower portions of the front flares were damaged.
The splitter we built is stout, and when it pushed back and came off it poked a hole in the A/C condenser, so that was removed and the lines capped for now. A replacement isn't costly (less than $120) but we have only used the A/C system once this year, during the Optima Street Car road rally, and it is limiting airflow to the Mishimoto radiator. One step of the repairs were to make some templates for patches of red race roll (plastic) to fix the flares. These fender flares are going to be completely replaced at some point (likely with a composite front fender that a buddy's shop is working on) but for now we just patched the broken lower edges - you can't even see the repairs at speed, not with the unpainted black bumper cover on the front to distract you.
A new front bumper cover and side skirt were acquired from Ford, then the bumper cover was modified on the upper edge to fit around the aluminum airbox we have built to route air from the lower grill opening to the (now) front of the radiator. This detail is hidden behind the upper grill block-off plate. We had a spare CS lower fascia (that a customer discarded due to a minor scratch) so that was attached to the new bumper cover and splitter before it was all re-installed. Some minor repairs to the radiator's aluminum duct work were needed as well.
The same splitter that came off in the crash was virtually unscathed, save a couple of rear mounting holes that tore out along with the mounting bolts. We made some new holes to move the rear mounting plate 1/2 inch forward, sprayed some paint on the scratched lower face, and it all went back on. Nobody said 3/16" 6061-T6 aluminum plate was light, but it is damned sure strong. I've seen plastic and composite splitters that came off in similar crashes, usually doing as much or more associated body damage, but the splitter is almost always completely destroyed in the process. Not this beast - it also cuts grass like a mofo!
Of course I am determined to
not have this type of brake system failure again, and we've taken measures to that end, as shown in my last post. The 3" brake ducts, while more than adequate for so many S197 track drivers and racers, were not keeping the 14" front Brembos cool enough on our exceptionally heavy TT3 car (3802 pounds with driver). The Alcon temp strips indicating 490°F temps at the caliper should have been a BIG red flag, which I ignored (and we saw the results of that). That's near the boiling point of most hydraulic fluid and was just not a safe condition to leave the brakes at. So we have upgraded to larger 4" front bumper front duct opening using aluminum tubing and opening up the CS lower fascia from the 3" foglight hole with some careful cutting. You can see the new rear splitter mounting stanchion in the picture above right, and also where the old mounting holes in the splitter were torn out in the crash. That's all of the damage the splitter took.
The new front brake cooling duct openings were routed with 4" hoses but necked down onto the old brake backing plates' 3" ducts. We ran out of time to make new brake backing plates before the ECR track event. I was also curious to see if the larger hoses and front openings would help the brake cooling when even with that smaller restriction at the rotor. Our guys here at Vorshlag got everything repaired, new brake pads/rotors/fluid, nut-and-bolt checked, re-aligned, weighed and corner balanced, and the front brake ducts/hoses upgraded in about 2 days time, then loaded the car into our trailer to verify the repairs at a local HPDE event at Eagles Canyon on May 24th - less than 2 weeks after the crash.
Front Wheel Hubs - Diagnosis and Repair
One of the common wear items on an S197 Mustang, and all cars for that matter, is the front hubs. We recently had to replace the fronts, so I made this little video to show what bad bearings sound like, and what it takes to replace them.
The video above shows what you should do for quick diagnosis, and should be on your pre-track check list. Every. Time. We check the hubs whenever we do any track inspections here, and we've found bad front hubs on Mustangs a number of times. This is actually the 4th set that we've replaced on our 2011 GT since we picked it up in August of 2010. As the grip levels and brake heat go up the lifespan of the hubs goes down. 4 sets of hubs in 4 years ain't bad, considering the lap times this heavy beast puts down and the brake heat numbers we've seen.
We actually replaced these hubs after the ECR event (detailed below) but before we went to Hallett. They were fine before ECR but they weren't afterwards. Vorshlag stocks and sells this
FMS-M-1104-A motorsports hub kit, which comes with the 3" ARP hardened wheel studs installed plus new spindle nuts (which are one-time-use nuts that need 250 ft-lbs of torque to seat). This kit is cheaper than buying new hubs and wheel studs separately, and they are already pressed in place.
We also have a variety of wheel spacers for the S197 and our reduced (17mm) hex/enlarged taper lug nuts for this chassis. These are the same 1/2"-20 right hand lug nuts a Ford uses, but with a smaller hex drive to fit inside aftermarket "lug wells" with a deep socket with more clearance to the wheel. The larger OEM (19mm) hex lug nuts often won't work with some wheels with a tighter lug well (like Forgestars). These lug nuts and wheel spacers are what we use on our car, and they are located in a new section of our shopping cart we have created
here.
continued below
