FYI - For Comparison
2008 V6 Premium, 8 gallons of fuel, 2010 front manual seats, gutted trunk, rear lower seat half removed, 9.5”x18” rims– P265-40-18, T-5 re-built w/ upgraded main shaft & gear cluster, 3.5” aluminum drive shaft, 8.8 rear end, Very, very heavy FRPP dual exhaust, Wilwood 6P-Superlights & 14" rotors, larger radiator, square tubing rear lower control arms & adjustable upper rear arm, FRPP lower front control arms, Koni yellows, Steeda springs, .875” solid rear sway bar, 1.375” tubular front sway bar – TONS of other little sht not changing weight much. All power accessories left operational. The car is a daily driver / training tool.
Total investment – $20,372.00 including cost of car- (Not including time).
3325 LBS
LF 924 RF 911
LR 752 RR 738
With my Fat Arse & gear - Wife is 100LBs less
3527 LBS
LF 1007 RF 919
LR 820 RR 781
If my wife gets serious 65LBS approx. more weight added but better distributed & NASA TTC. Will stile be kept as a DD but manual rack. Currently she is running HPTD. NASA TTC - Way too heavy to be competetive.
3325 LBS
LF 924 RF 911
LR 752 RR 738
3527 LBS
LF 1007 RF 919
LR 820 RR 781
