weird electrical problem!! help please
BULLITT1
SPRING, TX
2009 mustang bullitt
dash error indicator lights:
Oil pressure low
brake fluid level low
fuel level low
tire pressure monitor fault
fuel level low dte fli data err
parking brake on
_______________________________________________
fuel level and battery voltage gauges read zero
radio stops working only shows time when press radio on button
was out and about to get lunch, 5 minutes into driving and all these lights and error messages start appearing. Has anyone seen anything like this? Any help is greatly appreciated.
Thanks in advance!!
skwerl
tree hugger
central Florida
Water intrusion in the SJB (smart junction box) passenger side footwell behind the kick panel. Water gets in from the cowling at the base of the windshield.
BULLITT1
SPRING, TX
Found small amount of water in the juke under the carpet. Still trying to isolate leak. Messed around with junction connector, short somwhere in power side. Just have to figure out what component this water is sitting in, repair and seal it up . Will find out. Saturday.
BULLITT1
SPRING, TX
AWESOME, THANK YOU VERY MUCH, THIS WILL HELP FIGURE OUT MY ELECTRICAL COMPONENT ISSUE LOCATION,
working on lexus is certainly different than ford.
BruceH
BBB Big Bore Boss 322
Oil pressure low
fuel level low
parking brake on
Thanks in advance!!
This is how the display acts when the alternator and or battery go out. Are you on the original battery and alternator?
BULLITT1
SPRING, TX
Interstate battery and oem alternator. 13.7v idle
Gr8 tester show battery 89%
I measure 14.2 to 14.3 at idle. It doesn't drop with heat on, headlights, stereo, both seat warmer's on, rear window defroster etc.
BULLITT1
SPRING, TX
Lately has been raining here. So i figure its related. Water under carpet in the juke.
BULLITT1
SPRING, TX
Have been out of time for a while. Just got to look at her. Found dryrotted firewall grommet under the cabin filter. All water drained through and onto floorboard. Thank you all for the right direction
