bossmanpena
Team OverDrive
i dont have many power adders at all just a c&l cai and tune but id like more stopping power.. should i do GT brakes?
Better pads make a big difference. Although, good hawk hps pads+gt brakes, which is what I use, helped quite a bit. Remember, your back brake rotors are already the same size as on a stock GT; just the fronts are different sized.
I heard about the Hawk HPS pads squeel but never witnessed it or had first hand experience. Do you own some? Is that true? Hopefully this can help the OP decide too
anyone else using monroe brake pads? I am shopping for brake pads and since I get monroe brake pads at 50% off I thought I would give em a try.Get Monroe Pads, do a good brake fluid bleed if your fluids been around for a bit and you'll stop on a dime. Same set up, stock calipers and I don't have ABS or TC and I stop pretty well!
if you have 17+ wheels, yes. big improvementi dont have many power adders at all just a c&l cai and tune but id like more stopping power.. should i do GT brakes?
