I like the looks of the PLX gauge. Can you get it with a chrome/aluminum looking bezzle?
Skip a fuel pressure gauge! We have a fuel rail pressure sensor stock on the driver's side fuel rail. Can be read with an Aeroforce, ScanGauge, DashHawk, or similar multi gauge that can plug into the OBD II port. Plus, you will be able to read dozens of other parameters like cylinder head temp, coolant temp, voltage, inlet air temp, mpg, mph, rpm, gph, etc.
I have an Autometer fuel pressure gauge with the sensor remotely mounted inside the drivers wheel well. Either it or the gauge is bad since it never reads the right fuel pressure. What a waste, for the $200 I paid for it, I could and should have got a wideband. Going to take it out one day and put a wideband.
I have had a DashHawk and a ScanGauge, and neither could read Oil Pressure through the OBD II. Can the Aeroforce?
