Looking for hp guesses on my new setup. I should be getting it tuned in a couple of weeks. The parts list is as follows:
Manley pistons, about 9.1:1 compression
eagle rods stock stroke
eagle crank
39 lb injectors
dual frpp pumps
3:55 gears
stage 3 spec clutch
Spec steel flywheel
otherwise stock 5 speed
Stock block bored 30 over (I know not ideal but I'm not going over 14#)
Arp studs all around
Twin 62 tb
Kooks lts and x pipe
Techco 3L twin screw (probably 14 lbs, is what I expect)
Stock heads and cams
On 7# with 4:10s, stock motor, stock clutch, and stock exhaust it made 440whp.
I'm thinking 520 whp, but I really don't know for sure. Guesses?
eagle crank
39 lb injectors
dual frpp pumps
3:55 gears
stage 3 spec clutch
Spec steel flywheel
Twin 62 tb
