Bullitt3478
Exactly how many moles perished in this thread alone???Kiddin
I have an 08 and I don't even window tint, but something inside the window straight up is cuting into my window. Has anyone else had this issue? It does not make any noice or anything when going up or down but you can see were it is cuting vertical lines into the window!
I have an 08 and I don't even have window tint, but something inside the window straight up is cuting into my window. Has anyone else had this issue? It does not make any noice or anything when going up or down but you can see were it is cuting vertical lines into the window!
You also might want to look at www.tintprotector.com {mole skin} $30 a pair.
Had the same issue with my 07, went with the FOMOCO 08 replacements and no issues since. The mole skin is cheaper but for me I did not want to mess with the adhesive crap. The 08 and above FOMOCO replacements are built in, no worries so far !
If you roll your windows down a lot and don't see anything after 2 months, then you should be fine. My glass was never scratched prior to getting tint...but the tint is a lot softer than the glass.I wonder if the 2011's have this issue? I've had my tint on for two months now and haven't noticed any scratches. But beyond that, I don't want my friggin glass to get scratched either. If it goes through the tint and into the glass, the windows will never be tintable after that.
I may just do this as preventative maintenance.
Tell me more, part number? thanks
Black Baby II, Does this look like this is it and thanks.
https://www.partswebsite.com/titusw...tid=0&type=parts&image=JC05700&imagecallout=6 Number 6 ?
or this one
https://www.partswebsite.com/titusw...d=30188&subcatid=57629§ion=157&type=parts
It is the first one #6. You can allways call the stealership and they can run the part numbers for you as well. A bit more than than the moleskin but it was worth it to me.
Bought from tintprotector.com and replaced the scratched tint - no problems since. The moleskin from tintprotector is not a hard install.
