DynoJoe
cleaning out your closet
Which flywheel is best for performance?
The Aluminum Flywheel. It will accelerate faster. You will give up some idle quality and you'll need to raise the idle speed for more stability due to the less inertia. this is something you should ask your tuner to do in your tune to make up for the idle speed lowering caused by the Lightweight flywheel.
The car will be faster with a lighter flywheel as well, not only in the 1/4 mile but also on any road you drive the car. It may only be a small percentage faster, but Faster non the less.
From Ford the Cobra uses one, the Cobra R used one, the Roush Stage 3 uses one.
