Kalatrax
So I finished my turbo build a few months ago. Single 67mm comp journal bearing turbo. After getting my tune for 9 psi I started noticing a lot of smoke under boost. It will also smoke a little out of the tips for a few minutes after. At first I thought it might be oil seeping out of a seal. Checked the cold side, no oil. I'm running 10w30 synthetic oil, 10 an drain line straight to pan with no flat spots, 4 an feed line coming off of a sandwich adapter on my filter relocation kit. I had the car tuned with the passenger side venting through a breather and the driver side going back to the intake with a catch can in line. I then put a breather on the driver side and the oil cap. It made it worse. Like the title says, it's white smoke and doesnt have much odor, a little like fuel. The a/f is at 11.8 at WOT though. Any ideas?
