Who has the takeoff Bullit wheels with ET Streets?
US-1
Banned
The ShadowLands
Can't find that ad anywhere. Some company has take off wheels with M/T ET Streets (I think) mounted and balanced. Who the hell is it??????
/\ Brenspeed.... not mounted if I remember
Fastmover
Resident Fuktard
MD
Those are going to look tough! Is the lettering white on both sides or can you mount them so the black lettering in on the outside, that would be very sneaky.
LeftOvers
how well does that size tire fit on the 8 in. rim? doesnt MT recommend the smallest width of the rim to be 9 in.?
sc281
5.3 big bore block
SLC, Utah
I am looking for only two 18" bullett polished alum wheels. Same as factory Shelby GT's so I can get them widend.
dustindu4
They fit fine suprisingly. Tons of people use this setup including myself. I've seen 10 sec cars use it, it's fine.
I have a set in my basement that I use. The M/T tire white paint comes right off. The biasply tire is not a good street tire though and shouldn't be driven off the track
8
88_Stanga
Guest
I pulled off some 2.0s or 1.9s with 35 psi in my MT ET streets. Next time ill let some air out and run around 18psi in them.
with 15psi in mine i hit 1.7s. you can go as low as 12. the less air, the better they work....too a certain point
dustindu4
I run 13 psi and do a good burnout. line locks are your friend
SoundGuyDave
This Space For Rent
Hell, I cut 1.9's on street tires (285/40-18 Nitto 555s)... I would hope that you would gain more than just two tenths going to a bias-ply cheater slick... Seems like a pretty large PITA swapping out rims and tires for fairly minimal gain...
