Will the new batch of M&H tires still fit the stock rims.
gmantheman
Escondido, CA
I know the new 275/50/17 M&H DR are wider than the previous ones. Does anyone know if the new M&H will still fit the stock 17x8 rims?
ArtQ
Alpha, NJ
The 275/50/17 is also an inch wider. They fit on the stock 8" rim but baloon a little. I went with a 9" rim and like the fit better. On the stock rim I had to run the pressures lower than when the tire was smaller. I haven't tested on the 9" rims yet but I'm hoping to be able to run a higher pressure.
