For all you tech gurus, I have a quick question someone might be willing to answer. Does anyone know the standard square terminal our cars use. I'm going to order a large quantity when doing my project, starting in the next week or two. When doing the wire harnesses that need to be shortened I'm going to use these instead of splicing. That way it will be as clean as possible. Here are examples of several types. Just wondering if someone by chance had a part number or website I can order the exact terminals I need.
http://www.ebay.com/itm/Kent-Moore-Terminal-Repair-Kit-Lear-J-38125-Tray-17-/371258457226
I know most of them are. I'm going to be putting the fuse box behind the glove box so I was referring specifically to the big bundle running from underneath the dash all the way to the fuse box. I was also going to just start making wire harnesses with this terminal so when I get ready to extend wires i could just repin the connector and only have to splice at one point instead of two.
Has anyone found a way to leave the AC but redo the routing of the hard lines?
I pulled it all inside, coiled it up above the bar that runs behind the dash.
