Almost all of the gas stations in PA and NJ, the two states I drive in the most, use 10% ethanol gasoline. I have the SCT pro racer package and I was considering making a tune for 10% ethanol gasoline. Most of what I read about 10% ethanol pump gas says that the for E10 the stoichiometric air:fuel ratio is 14:1. Also, to get the most power at WOT, I assume I should program it to run a bit richer than I would with 100% gasoline.
The things I was wondering about were:
Pump gas definitely doesn't have the quality control that race gas does, so is it even worth it to bother with the time to create a 10% ethanol tune?
What air/fuel ratio should I aim for at WOT with 10% Ethanol?
Is there anything else I should change in the tune for 10% ethanol gasoline?
Since pump gas doesn't have the quality control of race gas, if I got a tank of 7% ethanol or 9% ethanol, would it affect the tune much? I wouldn't be adjusting the timing more than a few degrees more than I would with 100% gasoline. If there is a little knock, wouldn't the PCM adjust for this?
Searching, I found many threads about E85, but not much about the E10 that many parts of the country are cursed with.
