The crank walked and beat the back of the oil pump until it cracked. Twice.. The original shortblock I ordered was a 4.75L 11.5:1 MMR1000. It never made over 450whp, I used a Ram powergrip hd clutch and stock slave cylinder. Slave cylinder throw was checked, and dead on with Rams recommended specs. The first time the engine went down, they blamed me and said anytime you run an aftermarket clutch, you need an adjustable slave to properly set it up. I agree if it's out of spec, but it wasn't. So $1,500 later they fixed my engine. I noticed, the thrust bearing looked different from the other. I called and asked why the one that came with the engine was a 1-piece, and the one in the engine now is a 3-piece. They said that there was nothing wrong with the original design, but they are always looking to find a better design. Well there better design lasted only 2 months and 2,000 miles. That car has been sitting for 2 months. The first time the engine blew, I was sitting in traffic on a friday evening coming home from work. The second time, I was moving my car from the front of the house to the back so I could mow my yard. Now they say they have nothing to do with it, and the bad thing is, this time, It trashed the Comp SPR stage 3's and Livernois Stage 2 heads from where it lost oil pressure..
