F
FordEvangelist
Guest
Finally got my car to the track with the software (SCT) two-step setup. It actually worked pretty good. I set the Neutral 0 rev limiter to 5500RPM and set the Rev Limit Speed To Exit MPH to .2mph. See the image below.
I also removed the top clutch plunger switch from its mounting bracket and taped the switch into a permanent closed position and tucked it into the driver's side kick panel area. This prevented the bog between shifts. There was none.
Am mounting a toggle switch to override the clutch switch next weekend. Will be cleaner.
60's were 1.67 - 1.74. I usually am in hte 1.76/8 range and only got a 1.6x one time in very cold weather on a well prepped track before. It was 3100'DA last night.
I ended up settling on 5500RPM and 15 1/2 psi in my ET Streets.
I know a Wotbox is a better all around solution but I don't want to mess with it. When this is cutting out fuel it's not in boost so I'm not worried about that.
