Xcal2 stock reflash?
Shotokan1509
CT
I need to temporarily reflash my car to the factory tune, how do I do this? Probably simple but I do not want to make a mistake and delete the custom tune in the tuner. :helpme:
ixtlan
Hooper, Utah
Install Tune
Select: Return to Stock
Return to Stock will not erase the custom tune in the XC2.
Shotokan1509
CT
Install Tune
Ok, and is there anything particular with the S197 to get all monitors ready? Over the years have heard 150 miles, or do this, this, and that.. blah blah. I'd rather drive it with the stock tune the shortest amount as possible.
Shotokan1509
CT
You cant run a Aftermarket Intake with the Stock Profile.
You will be extreme lean.
But here is the process:
http://www.s197forum.com/forum/showthread.php?t=23499
I have a BBK on the car which says:
"Designed to work in most cases without modifications or any tune, these BBK cold air kits work with the factory computer"
Considering that is the only aftermarket part left that should affect a tune, thinking it'll be fine.
Thanks for the link, some great info in there :clap:
