I have searched, but have not found this exact issue!
I am fitting my Race Stars for the first time and am running into an issue. There appears to be a minor difference in the “offset” of the offset washers between the Race Stars and the McGard’s from Lug/Washer set part number 63000. The difference is not significant but enough to have the McGard washer not sit flat against the wheel with the lug nut threaded. As I tighten McGard washer and lug nut I can definitely feel it binding and can see that the washer is not sitting flat. The Race Star washer McGard lug nut can easily be turned down by hand and the washer is definitely flat against the wheel.
Both pictures illustrate the difference in the offset. The first has the McGard washer to the left and the second the Race Star washer to the left. (Not the best pictures but I think you can see the difference in offset)
Did anyone come across this issue?
It would be appreciated if someone would compare their Race Star and McGard washers and advise if they have a similar difference?
Or am I too cautious after reading all the threads on issues with the lug nuts and washers, and I should just go for it with the McGard's?
