blew my rear at 4,000rpm
RedFire07GT
11sec N/A 3V
Ocean County, NJ
My little brother came up to me in the pits and told me about this, said alls he heard was a big bang.. Any plans on upgrading it now?
Brandon
fdjizm
Drag Queen
It sounds like it just ate the teeth off the pinion, might not be that bad.
PNR Welding
Hammonton, NJ
Yup, that is what I thought it was also. Johnny Lightning seen it and told him it was an axle, but I told Chelo that it is very rarely that these axles break due to the stock ones being 31 spline hardened shafts. My money is on a busted ring or pinion gear, (probably both). Especially since he says it will spin about a half turn then lock up in first gear. Then in reverse it does the same, spin a little then lock up. That is what happened to me, and I broke my rear about 4 different times in this car.
06GTMustang89
Corner Carver
Cary Area, NC
same thing happened to me on saturday...except it was a little more damage...my eaton posi basically exploded and shot the pinion shaft through the housing
good luck with the build man...
dysan
Dis-Member
Williamstown, N.J.
Dang dude....just thought of a good name...
CAPTAIN CARNAGE OF THE REAR!!!!
hehe....
I'm sure you'll get her back up and running real quick.
JCuZzO1
Cajun JiHAd RaCinG
Houma,LA
How Many Launches (on slicks) Would you say you got out of it before it let go?
VTXFrank
Obama SUCKS!
Santa Rosa Beach, FL
Damn. The pinion turned queer and ate itself from the looks of it. Took out both shafts during the process. Is the ring gear trashed as well? I think I can see some damage to it.
cruzing2much
hammonton,nj
the rear is completely toast only the axles were salvagable just got done swaping out rears ready to go for sunday!!!!!!!!! lets see how long this one last.:dead2:
