FRPP motor mounts for pushrod 302/351w
dream07
Eastern PA
I have a brand new set of FRPP M-6038-CJPR solid motor mounts that allow you to put a pushrod 302 or 351w or even a 351c into a 2005-2013 Mustang. Ford Racing sells at $199.
Imagine having a carb, no computer, no tuner, and look at all that room!
Never used due to job loss. Scrapped plans. Located in Eastern PA.
My price is $150 shipped/obo.
dream07
Eastern PA
Yes, still for sale. PM me here or email at [email protected]
As far as headers go, I can't really say. I know all the short tube headers will fit, but as far as long tubes go it would be a guess. If you look at Ford's pushrod Cobra Jet car below, you can see there is a MILE of room around the engine in the s197 engine bay!!!
That being said, if you have Fox-body longtubes or the Hooker sn95 351w swap headers, as long as they clear your transmission of choice they should fit. The Fox steering shaft and k-member is a lot more restrictive than the s197. You will likely be able to install the headers from inside the engine compartment saving all that crawling underneath. Of course, someone who races the Ford CJ cars like John Calvert or Chris Holbrook could answer you 100% sure (even though they probably use custom headers for maximum power).
51 Mustang
Alabama
Do you still have those motor mounts. Im planning on installing a 302w into a s197 chassis to create an endurance racecar. They don't make the bracket anymore.
