I got the brackets installed today....should I put a couple of stitch weld on just in case...I really don't want any unusual noises!
Mine are welded in... but then again, I had no other option. They aren't a bolt-in design.
Bolt them in now - weld them later when you get faster or hear some noise...weld and bolt in maby ........lol
The Shock Bracket Kit is designed to be used with the Axle Bracket Kit when ever increased rigidity of the shock bracket is needed such as those exerted by extreme cornering forces with good adhesion. This is accomplished by tying the Axle Bracket to the aft Rear Lower Control Arm mounting point and optionally welding in the steel reinforcement gusset.
