Sorry i should have put in original post, i put the stocker back in, going to try to sell or trade the car. Yes everything is included that came with it, the 4 bolts needed are screwed into shifter as seen in pics, the back bracket uses stock bolts and the two arms use the stock pins to attach to trans. Also the shift linkage uses the stock bolt and nut. And if you search (barton shifter,gt 500) on youtube you will find the install video
sent from zombie land
