what bleeder did you crack? there is no cracking of any bleeder to bleed the hydraulic clutch.
You need to get a vacuum gun.
http://www.mityvac.com/pages/products_hvpo.asp
you get a rubber stopper large enough that it can plug the top of the master brake cylinder and punch a small hose in it. Just enough to get the rubber tube from the vacuum gun through and you plug the master cylinder.
using the vacuum gun, you pump to and hold 20 inches of vacuum for 30 seconds and release.
replace the master brake cylinder cap and pump the clutch 10-15 times.
repeat this process at least 3-4 times to ensure you have properly bled the clutch
