Fuel line crossover removal
fastregalwe2
Need more powa!
Virginia Beach, VA
Anyone know how to remove that fuel line crossover that gos to each rail in the center?
Trying to remove the saleen blower lid but that damn line is in the way
TIA
v6tungsten
Wylie, TX
Only way is to unbolt one of the fuel rails and slide through the opening. you will need to remove the injectors. saleen install instructions are the opposite. they have you slide the rail through the opening then install injectors.
fastregalwe2
Need more powa!
Virginia Beach, VA
I peeled a little of that thin covering off and saw it was the heat shrink style tubing so I did just what you said. Thanks for the reply
BruceH
BBB Big Bore Boss 322
If you replace it with line from the auto parts store be sure to get fuel injection rated line. You might already know that but it's worth repeating.
