Now Introducing: Weekend Wrench
Harrisburg, PA
CJ Pony Parts is proud to announce another new Mustang project car: Weekend Wrench
The Weekend Wrench is a 1965 Mustang coupe that is like many other similar Mustangs available on the market—it's a perfectly drivable Mustang that offers plenty of opportunity for upgrades for the weekend hobbyist.
We're going to be working on the Weekend Wrench over the next several months, showing you how you can transform a basic Mustang using some popular CJ Pony Parts products and make it into a beautiful Mustang you'd be proud to show off at a car show or cruise night.
Do you have any ideas of what you'd like to see us do with our coupe? Connect with us on our Facebook and Twitter and share your thoughts!
Facebook: http://www.facebook.com/cjponyparts
Twitter: http://twitter.com/cjponyparts
Harrisburg, PA
Mustang Retro Sound Radio Model Two with Chrome Bezel and Knobs AM/FM 1965-1966 | CJ Pony Parts
For our first installation on our new Weekend Wrench project car, we installed the new Model Two radio from Retro Sound, which is the only made-for-iPod® radio available for your classic Mustang with full control and charging for your iPod®/iPhone®. Flexible mounting options are available using Retro Sound's "InfiniMount" shaft/bracket system, letting you install your Model Two with any Retro Sound vehicle specific bezel, plate and knob kit.
The first step in this installation requires removing the old radio and disconnecting its wires. Next, you'll need to run your power wires and ground wire for the new Retro Sound radio, and then install the power harness. Assembling the radio isn't difficult, and Bill demonstrates installation in our Weekend Wrench project car.
See more 1964-1973 Mustang Radios from CJ Pony Parts:
1964-1973 Mustang Radios | CJ Pony Parts
See more Retro Sound Mustang Parts from CJ Pony Parts:
Retro Sound Radios | Retrosound Mustang Radios | CJ Pony Parts
Harrisburg, PA
Mustang Scott Drake Ignition Switch Installation 1965-1966
Mustang Scott Drake Ignition Switch Assembly 1965-1966 | CJ Pony Parts
If you're having starting issues or your Mustang shuts off while driving, you might be able to fix this problem by replacing the ignition switch. Bill shows how to install the Scott Drake Ignition Switch Assembly on our Weekend Wrench new project car.
First, you remove the lock cylinder and then separate the ignition switch from the ignition bezel. You'll then remove the plug and replace it with your new ignition switch, and place the switch back into your dash. Total installation takes under an hour.
See more 1964-1973 Mustang Steering Columns from CJ Pony Parts:
1964-1973 Mustang Steering Column | CJ Pony Parts
See more Scott Drake Mustang Parts from CJ Pony Parts:
Scott Drake - Ford Mustang Parts - CJ Pony Parts
Harrisburg, PA
Mustang Scott Drake Shorty Billet Antenna Installation 1965-1968
Mustang Scott Drake Radio Antenna Billet 8" Shorty With Round Base 1965-1968 | CJ Pony Parts
Add a touch of personalization to your 1965-1968 Mustang with a Shorty Billet 8" Antenna from Scott Drake. This antenna features a modern looking 8" antenna mast with a round base that is clear anodized and machined from 6061-T6 billet aluminum.
Bill installs the Shorty Billet antenna on CJ's Weekend Wrench project car by first disconnecting the original antenna from the stereo. The next step includes removing the original antenna from the fender, but making sure to set aside the bracket to use for the new installation.
After fishing the new wire down into the fender and securing the new antenna, you will need to reconnect the wires to your radio under the dashboard. Installation takes up to 30 minutes.
See more 1964-1973 Mustang Antennas from CJ Pony Parts:
1964-1973 Mustang Antennas | CJ Pony Parts
See more Scott Drake products from CJ Pony Parts:
Harrisburg, PA
Mustang Kick Panel Speaker Installation 1965-1966
Mustang Speaker Kick Panel With 2-Way 160 Watt Speaker Pair Coupe/Fastback 1965-1966 | CJ Pony Parts
These direct replacement Mustang kick panels will fit in the original location of your factory kick panels while adding a convenient location to add some extra speakers without having to cut the interior of your Mustang.
Bill begins this installation on our Weekend Wrench project car by removing the door seal plates. You then connect the speaker wire to the speaker harness, making sure the wire extends over the top metal of the kick panel. After sliding the kick panel into place, the last step is to return your door seal plate back to its location. Total installation takes up to half an hour.
See more 1964-1973 Mustang Kick Panels from CJ Pony Parts:
See more 1964-1973 Mustang Speakers from CJ Pony Parts:
1964-1973 Mustang Speakers | CJ Pony Parts
Harrisburg, PA
The window regulator in our Weekend Wrench project car was practically shot, so Bill shows us how to replace it with a new part from Scott Drake, giving our 1965 Mustang coupe much more functional windows for the summer ahead.
After some interior restoration and a few modern upgrades to our Weekend Wrench project car, we realized that the trunk could use some attention. To continue modernizing this '65 coupe, we decided to switch out the plaid trunk carpet for a molded trunk carpet kit from Distinctive Industries.
