Mine is pretty much a clean simple install......everything is hidden except the plate and the purge.......you can't really see the switches unless you are looking for them and the Bottles are in the trunk and are only seen at shows.....
I also got a bottle heater/bracket for sale if you need one.....
Here are some pics.....Let me know if you want to see anything else and I will take some pics for you.....
Overall Engine Bay Shot....
Bottles in the Trunk.....
Switch Panel
Gauges.....and the RPM Switch is mounted in the glove box......BAP is mounted in the trunk but behind the panels and hidden.....Switch for the BAP is in glove box as well.....
Another Plate Shot.....Solenoids are hidden behind the plate for purge as well....tucked under the other side of the plenum cover.....WE just modified the plenum cover to be able to fit them perfectly....
Purge.....Mounted in the center of the windshield so that the purge cloud goes sprays up and over the car.....
