tmcolegr
It's All About the Build
How many of you have had to replace your rear crankshaft seal? Did you intentionally replace the seal because it was leaking or find the seal to be leaking while performing some other repair in that area - clutch, torque converter, etc? If you replaced the seal yourselves, was it the seal that was actually leaking, the retainer bolts loose, or the retainer leaking where it is sealed to the back of the block.
Upon disassembly we found that my rear seal had spun in the retainer.
