"Service AdvanceTrac"
Digital_Synapse
Texas
So I turned on my car the other night, and I heard a beep, like low fuel, looked down, and the TC was off. A warning came up saying Service AdvanceTrac, and I couldn't click it on or off, just stayed lit. So I took off like a bat out of hell and sure enough, no TC, just spun and spun, and drifted with no problems like stability control was off as well.
Later in the evening I turned the car on again to go home, and everything worked normal.
Anyone else have this happen? Should I service it, or did my computer just have a mini-stroke?
Kingcrabb
Cecil County, MD
My service AT came on at the track one night a couple times. It did it every time i would have real bad wheel hop. I just cleared it with my SCT and that was that.
Not sure what to really tell you. But i can say iv never had a problem with anything to this day.
Digital_Synapse
Texas
Yeah see, I had just turned on my car leaving FreeTails, and the light/chime came on instantly. Then drove it, parked it, turned it off. Few hours go by, turn it on, and its good. :/
cshiznitzj
I have had my car start applying brake to one wheel when going in straight line without acceleration. Just wigging out. Only happened once but I drive with the nanny off 99% time.
TX
not to hi-jack your post but , has anyone turned their a/t off and try to drift out of a corner, mine seems to cut the engine out for a sec like a/t is on anyways (2012 manual) dont know if that matters , i know i dont have skip shift like the 2011's do, so it made me curious if they might have changed anything. around a corner it seems to cut out.
DarkTrak
Small kine pimpin'
Hawaii
not to hi-jack your post but , has anyone turned their a/t off and try to drift out of a corner, mine seems to cut the engine out for a sec like a/t is on anyways (2012 manual) dont know if that matters , i know i dont have skip shift like the 2011's do, so it made me curious if they might have changed anything. in a stright line you can boil the tires! but around a corner it seems to cut out.
there are 3 TCS/ASC modes.
push button = TCS off/ stability on
Hold brake and double tap button = Sport mode
Hold brake and hold button for 8 seconds = Everything off.
JEWC_Motorsports
S197 Junkie
Texas
With tc and at off my car will spin the tires around a corner and in a straight line.
Mikes5.0
Dacula Ga
Happened to me once on the dyno. I turned the car off then back on and it went away
Lucky you, We had to unstrap my car from the dyno and drive around the corner to get my service light to go off. It was my mistake forgot to tell the guy how to turn both the adv track and trac control off.
Digital_Synapse
Texas
He should have known.
Decided on new wheels yet? The SVE's are looking hella sexi. :)
Mikes5.0
Dacula Ga
Yeah I hope so, the rear offset seems kinda week for a 10in wide (+51) but it looks like it might be flush. I cant wait to get them so I can sell the oem brembo wheels and buy a set of dedicated track wheels.
BMR Tech
Traction Vendor
Tampa, FL
You have to be stopped?
Shucks. We always hold the brake for 8 seconds while moving.....
Full_Tilt
I read something about exhaust mods casing an issue with advance trac. Apparently the pipes can get too close to the sensors and get them too hot.
I wish I knew more detail. I suppose Ill have to look out for these sensors when Im installing my axle backs.
