Zoom D2 Stage 2 twin disc clutch w/alum flywheel
blacknlte
Odessa, Tx
Ford Twin Disc Kits # Twin Disc Clutch Set2005-Up Mustang GT # Factor-2 Handles 920 lb/ft # Weighs 29.9lbs Disc Size: # Diameter 8-7/8'' # 26-spline D2-Series Twin Disc Clutch Sets Zoom's D2 Twin Disc clutch systems are designed for high horsepowered applications on the street. Zoom's new twin plate design provides high torque holding capacity while maintaining streetable driving conditions. Zoom uses CNC manufacturing processes and their performance friction material to achieve max torque handling capabilities. Kits are available in Factor-1 (600 lb/ft) or Factor-2 (920 lb/ft).
Zoom D2 Stage 2 twin disc clutch w/alum flywheel-6 bolt
26 spline
D&D says its rated for 900 to 1000 hp
It came with the 6 speed kit i bought a few months ago. I never installed it but the guy i bought the kit from did and it was only in for 600 miles.
Only reason im selling it is cause i will never own a Zoom cause of past zoom clutchs ive had and also im going to run the Spec twin disc setup for 8 bolt crank.
Just to being up front about it, i really dont know how it is as far as streetable or pedel feel is cause i never ran it.
New is about $1200 asking $550 shipped.
