TexasBlownV8
Formerly TexasBlownV6
Made 8 runs today, mostly around 13.0, with a couple in the high 12s, with a best of 12.88 @ 106 mph, on a 2.00 60' (which was my best, by the way). I run M/T 275/40-17 ET Streets on stock 17x8" rims, at different pressures. Historically, my best times are with 18-19psi, but a little (and I mean just a little) better traction with lower psis, down to 14.
I do a decent burnout, but at the line, always just spin the tires at launch, at least a little; and sometimes most of the ay through 1st or when getting into 2nd. Not nearly as bad as street tires, of course, but still not getting good power to the ground at launch, with all 60' times in the 2.0's and 2.1s. If I can just hook and not spin, I know I can knock at least a couple tenths off the 60'.
My V6 is an automatic, and I rev it up to 1800-2000 rpms, then floor it when taking off...and that's when I spin the most...taking off from the line.
Next time out I'll have someone videotape it, which I want to see what the suspension is doing, too (adjusting the d-specs to different values didn't seem to make much difference either).
Fellow Stangers running slicks can launch at high rpms (manuals of course) and hook right up with no spin at the launch. So the track is decent, just not sticky enough for my DR's it seems.
FWIW, last year I was able to hook on the same DRs at the line very nicely, for 2 runs (with 19psi in the DRs), and then the spinning/slipping began again and my times dropped off. That was before the recent gear change, so now I'm getting more torque to the wheels at launch.
I think it's time for some full slicks with appropriate rims. Any recommendations or other suggestions (or questons)?
