S197 408 Windsor swap
Because Racecar?
Good luck Art!
ArtQ
Alpha, NJ
Needed the scoop for stock hood clearance. MMD, fits pretty good.
MIKE93SVT
Savior of Junk
Hawaii
awesome! mind sharing some info? engine combo, k member used, weight goal?
Mike
ArtQ
Alpha, NJ
351 roller block stroked to 408, 205 race ported Trick Flow heads, 10.5:1 compression, .600 lift roller cam, Comp 1.6 roller rockers, 850 Quick fuel carb. Should weigh in about 3200 with driver. The K member is from BMR but they don't make it anymore, however they do sell one without motor mount plates, So you can get one and weld it up the way you want it.
Alternator bracket to stiffen things up a bit, made, coolant hoses routed and installed.
ArtQ
Alpha, NJ
BMR extreme anti roll bar and Cobra Jet springs went in today.
What ETs r u expecting Art?
ArtQ
Alpha, NJ
Should run low to mid 10's easy. I plan on running the 11.50 index so I will use an Easy plate system (Variable size restrictor plates) to slow it down for that class. Should run the number even in the heat of the summer. It's only legal to 10.0, I'm sure I'll run it out once it's squared away just to see what it will do.
psfracer
billy badass
Valencia, CA
Looks like a great build. I used the same Lokar pedal for the accelerator pedal.
