FRPP Intake Manifold with Turbo Results
Results are up on page 2!
Figured i would start the thread today so I all I will have to is post the results, pics and dynographs tommorow.
So I talked to Mike Rousch today and confirmed the time. I'm Headed out to Mid-Atlantic Performance in richmond tommorow at noon to install/test the Frpp 3v intake on my turbo setup.
The plan is to head up there and do a couple baseline runs for an accurate before and after comparison. Then install the new manifold on the dyno and with no other changes, see what it will do. Then go ahead and swap in the ba5000 maf and retune and up the boost possibley if the fuel will support it.
The car:
Im already running steeda cmcdp, bbk 62mm tb and comp 127300 cams on stock heads. Built shortblock 9.1:1 compression, stock displacement, no overbore. Precision 67mm turbo with eboost2 controller and its currently making 12psi well (11.8). The eboost2 records peak boost and i will record/monitor it on the before and after runs to see if theres a change.
The only modification for the testing will be the frpp manifold unless the a/f needs adjusted and i will make note of that as well.
Will have pics and hopefully some vids, as well as the dynosheets.
Staye tuned!
Some teaser pics.
eng943
The plan is to head up there and do a couple baseline runs for an accurate before and after. Then install the new manifold on the dyno and with no other changes see what it will do. Then go ahead and swap in the ba5000 maf and retune and up the boost possibley if the fuel will support it.
The car:
The only modification will be the frpp manifold.
Staye tuned!
Some teaser pics.
Subscribing. Have you figured a way to make the FRPP manifold work with the Shaker?
Havent heard/seen a way with the shaker yet for the frpp manifold im sure someone will come up with it sooner or later. the big difference is the frpp manifold is not flat on top. It has a fwd to aft slope and is a little over inch taller in the rear.
lostsoul
2014 vett or 2015 stang..
Gay Area
can you take out the cams before the test? :naughty1:
J/K: Wish you big luck.. dont run out of fuel now.. haha
haha. nope. Its still going to be a true before and after regardless, since the cams are there for the stock manifold numbers already. Only change is the frpp manifold.
Vashthe3rd
Maximum Trolling
Damn by the looks of things I need to get a built shortblock and a new manifold
Too bad I just got a new level10 tranny with their billet converter ordered.
Towelly
Gonna be a sweet setup lightblade. I'm with this ^ guy. :p
